Old 20-03-2017, 10:52 PM
mkm492 mkm492 is offline
Default No Green Flicker
Bought and installed HSF4 with Howerton 2 gallon tank in 2012. System has worked flawlessly for 40K miles (modified 2011 EVOX.) A week or so ago, no bars and no green light (No flicker at startup.) Always use pure Methanol/distilled water 50/50. Car has boost cut failsafe. Get trouble code 304 frequently now, just occasionally in the past. I'll go through the electrical tests, but I don't expect to find a loose wire causing the problem. Any thoughts would prolly save me a lot of time. Thanks
90 AWD Talon
91 FWD Talon
11 EVO X
1965 Shelby Cobra Replica (427 Dual Quad FiTech)
Old 21-03-2017, 08:19 AM
Default Re: No Green Flicker
1. Can you check the green wire of the grey connector again, make sure is secured.
2. Measure the voltage at test point 8 at pre-crank and "run" key position.
What is trouble code 304?
Old 23-03-2017, 12:08 AM
304 is lean bank 4. I'll check voltage at point 8.
Previous interchanges with Jeff H. (Its in reverse sequence):
No. If you put the board in test it should spray. You've grounded the green wire and it sprays. I can't see why it wouldn't work connected to the car. May have to email Aquamist and ask what to try.
On Mar 21, 2017, at 8:46 PM, Michael Mathieu <mkm492@gmail.com> wrote:
It appears everything is hooked up correctly. The only issues are that the green LED does not light or flicker during startup/initialization, under acceleration, not even when feeding a ground to the injector. I could go through manual testing procedures as per set up instructions tomorrow, but I don’t think I’ll learn anything new. I didn’t do any electrical work to the car, it just stopped working. Is there a way to test the board itself? Looks good on a visual inspection, so no obvious burns. Seems like something must have burned out/failed on the board. Any other ideas? Mike
On Mar 21, 2017, at 8:40 PM, Jeff Howerton <jhowerton@sbcglobal.net> wrote:
When the Ecu fires the fuel injector it grounds one side. That's all the Aquamist looks for. Tapping it to a ground is theoretically the same thing.
Sent from my iPhone
On Mar 21, 2017, at 5:37 PM, Mkm492 <mkm492@gmail.com> wrote:
Wasn't getting any bars hooked up normally. Only action came with giving neg injector a ground
Sent from my iPhone
On Mar 21, 2017, at 7:29 PM, Jeff Howerton <jhowerton@sbcglobal.net> wrote:
Sounds like it's working. Not sure why the green IDC light won't come on but if you have spray then the system seems to be working. If you tap it real fast you can't get the the light to flash at all? If it sprays like that it should work hooked to the injector too.
Jeff
Store/Info at howertonengineering.com
To: Jeff Howerton <jhowerton@sbcglobal.net>
Sent: Tuesday, March 21, 2017 4:27 PM
Subject: Re: NO GREEN LED ON GAUGE
Got bars too
Sent from my iPhone
On Mar 21, 2017, at 7:03 PM, Jeff Howerton <jhowerton@sbcglobal.net> wrote:
Yes
Jeff
Sent: Tuesday, March 21, 2017 3:59 PM
You mean the ECM plug green wire that goes to -injector lead?
Sent from my iPhone
On Mar 21, 2017, at 6:13 PM, Jeff Howerton <jhowerton@sbcglobal.net> wrote:
The test for the controller would be to take green wire of grey harness and tap against a ground and see if the green light on controller flashes.
Sent from my iPhone
On Mar 21, 2017, at 3:08 PM, Michael Mathieu <mkm492@gmail.com> wrote:
No. I’ve done nothing to car but change oil/filter for a couple years now.
On Mar 21, 2017, at 4:58 PM, Jeff Howerton <info@howertonengineering.com> wrote:
If the kit is turning on(red wire) and the green is connected right you should get the green flashing IDC light inside the controller unless you've burnt the controller. Did you do ANY work at all recently?
Jeff
To: Jeff Howerton <info@howertonengineering.com>
Sent: Tuesday, March 21, 2017 1:39 PM
Checked wiring. Green wire to injector was good. Red had a couple frays so I resoldered it. No shorts. 14 ohms across red/green (injector). Any other ideas?
Sent from my iPhone
On Mar 21, 2017, at 9:25 AM, Jeff Howerton <info@howertonengineering.com> wrote:
You lost the fuel injector connection. Check your wiring.
Jeff
Sent: Monday, March 20, 2017 9:27 PM
No. The yellow light comes on for 5 seconds, goes out, then the “S” comes on solid. No green flicker with RPM, no bars.
On Mar 21, 2017, at 12:25 AM, Jeff Howerton <info@howertonengineering.com> wrote:
"S" light on gauge or all dead?
Sounds like power loss to the gauge. Bad cable? Power loss to the whole system?
Jeff
To: info@howertonengineering.com
Sent: Monday, March 20, 2017 8:59 PM
Subject: NO GREEN LED ON GAUGE
Bought HSF4 and 2 gallon tank from you five years ago. ~50K flawless miles. Last week problem started: No bars, no green LED flicker on startup. All other start up indicators normal. Any ideas what to troubleshoot or whats wrong? Thanks. Mike
90 AWD Talon
91 FWD Talon
11 EVO X
Old 23-03-2017, 12:17 AM
Is point 8 the unused "Default" at the jumpers?
90 AWD Talon
91 FWD Talon
11 EVO X
Old 23-03-2017, 07:40 PM
Pin 8 is the injector (-). It should read +12v at pre-crank and 13.8V at run.
Check the little green wire of the grey harness is connected securely.
Old 23-03-2017, 08:01 PM
I'll recheck it. (I didnt check it with the car running, and assume 13.8V means it should have been.) If that doesnt work I'll run a wire tap from injector to ECU plug green of controller.
90 AWD Talon
91 FWD Talon
11 EVO X
Old 23-03-2017, 09:58 PM
14.4 V at pin 8 running
12.2 V pre crank (not running)
(I have access now to translator for the Queen's English)
90 AWD Talon
91 FWD Talon
11 EVO X
Old 24-03-2017, 07:47 AM
Please take a Hi-resolution picture of the top and underside of the circuit board and post it here.
Old 24-03-2017, 05:39 PM
cid:AB9DF095-549D-4790-AA08-701DE5AED231
File Type: jpg IMG_2870.jpg (157 Bytes, 9 views)
File Type: jpg IMG_2871.jpg (157 Bytes, 10 views)
90 AWD Talon
91 FWD Talon
11 EVO X
Old 24-03-2017, 05:40 PM
having issues attaching images
90 AWD Talon
91 FWD Talon
11 EVO X
