Old 26-11-2010, 07:37 AM
Default WI error on dyno but not on road!
Hi,
my system is HFS-5 dds3 v8, 2 x 0.5mm.
Any idea why I get WI error (with the wanted boost limiting effect) during dyno pulls, but not on road pulls??
I have plenty of water so it's not a water level issue...
Thank you.
Wolf_Tm250 [Silat-Kali lover]
TM enduro 250cc 2stroke
Old 30-11-2010, 01:34 AM
Howerton Engineering
Default Re: WI error on dyno but not on road!
How do you have the gauge spanned (SC setting)? Does it come on at about 2 bars and finish at 6-7 bars at redline?
When does the system failsafe happen, at the start of the pull or the end and what is the gauge reading when it does?
Old 30-11-2010, 02:09 AM
The failsafe happened many times at midrange, around 5000 rpm, when WI is injecting huge quantity...
Yes, bars are still from 2 to 6...
Is there a way to know if failsafe happens for a WL or a WH problem?
Old 30-11-2010, 03:50 AM
The WL covers the left 4 bars and the WH the right 4. You would have to see what the unit is displaying when the failsafe trips.
Old 30-11-2010, 04:49 PM
Ok thanks.
Moreover during dyno pulls the WI failsafe comes on and off continuously and intermittently whenthe WI flow is at his max... so maybe is just a too narrow window problem...
Old 30-11-2010, 05:02 PM
Could be the WH needs to be adjusted a little.
Sounds like you don't drive your car hard enough on the road.
Old 30-11-2010, 05:05 PM
I hope it is!
Yep...too hard to drive WOT a Group B car on the road...
Old 04-12-2010, 12:22 AM
As I get errors even at 30% DC and not only at my max DC (70%), is there a logic in the DDS3 that relates flow to DC to understand if there is an error?
Just trying to understand better the system...
Old 04-12-2010, 07:25 AM
I'm trying to understand when it is happening. You said above it happens at 5000RPM, but it also occurs at 30% and 70%DC.
It would help to know what the gauge is showing for flow when it is occurring.
Old 04-12-2010, 12:07 PM
Ok...
I don't remember exactly (unfortunately...) what the gauge was showing, but looking at my logs, I realized it happened on full turbo boost from 3500 to 5000 rpm, when WI DC was at 30% and up...
That's why I wanted to understand how the window works... that is to say if the error comes out when a maximum flow is exceeded in spite of the DC, OR the maximum flow is related to that istant DC...
