Old 04-08-2015, 08:02 PM
upnorthstar upnorthstar is offline
Default Jet sizing for Hellcat
Hi Richard; need help with jet sizing for Hellcat...HFS-3 with red circuit board...8 x 600cc injectors, 11psi max of boost, 50-50 mix
would 2 x .8mm suffice?
or should i go 2 x .9mm and dial it back?
and finally what restrictor should i use? .9mm?
thanks
Old 04-08-2015, 08:10 PM
Default Re: Jet sizing for Hellcat
I have these jets 1x .8mm , 1 x .9mm and 1 x 1mm...
could I use the .8mm and the .9mm?
thanks
Old 06-08-2015, 04:18 PM
blk01s4 blk01s4 is offline
http://howertonengineering.com/tech-...ating-jetting/
Old 06-08-2015, 07:12 PM
thanks
What is the maximum duty cycle% of the fuel injector you are using?
