8-71 on a 400 ci Small block Chevy
I'm looking to build a roots supercharged engine and am wondering if anyone here as used, or seen water/Meth injection for a set up like this? First is it possible since I'm using carbs? Anu info would be great. I want to run a max of 15 psi on 93 octane fuel - 8:1 compression.
You can put a boost activated WI system that come in near the maximum torque region (most likely tio knock).
