Old 28-04-2012, 04:51 PM
Dust Dust is offline
Default Why don't we see more PWMV kits on diesels
Most forums are full of Pps kits. Is there a reason for the lack of PWMV kits on diesels, big or small?
Old 29-04-2012, 12:49 PM
Default Re: Why don't we see more PWMV kits on diesels
Probably for reasons listed below:
1. We did not market many PWM systems to the diesels because older diesels have little electronic controller for us to read the load signal from.
2. We have not produced a boost based, PWM system until the HFS-4.
3. We are unable to compete with the PPS system marketed around 200-300 dollars.
4. Unlike Gasoline engine, Diesel engine is basically a excess-air system, if you want power, just add fuel. Fuel can be diesel, cooking oil or any alcohol.
5. We will be looking into this market this year, it will be hard work to change the current trend of thoughts.
It amazed me that people one particular forum rarely venture out of their comfort zone, such as trying out newer technologies, or simply visit other forums. Do you think the PWM system will benefit the diesel community?
Old 29-04-2012, 03:06 PM
Some are spending up to $800 for the stage 3 blah blah blah stuff.
Sounds like the turbo buick crowd. The only kit that works on TBs is the Alkycontrol kit. Nothing else works. Which forum are you referring to?
I think it will benefit, but I think that without some incentive, it will be a tough sale. The main focus of diesel owners, big diesel owners, is HP, MPG, and flow. The big power diesels go with belt driven pumps putting out 600 psi to overcome boost pressure. With the stage 3 setups that include two nozzles that trigger separately, I don’t see the single stage setup of the HFS-4 having a whizbang factor. I think that an HP gain compared to a PPS system, and an MPG gain would be necessary. I don’t know if efficiency would matter much, as they run big tanks anyway. For the smaller stuff, not so much in the US, I would think a DI PWI-1 would be perfect. Don’t need that much flow for a 120hp diesel, and mounting the small pump would be much simpler than a big aquatic.
Old 30-04-2012, 09:12 AM
Forums such as the topics on cummins, GM, banks and diesel trucks.
Gasoline engine requires good control of AFR to maintain consistant power. Diesel has plenty of air, power output is directly proportional to amount fuel dump into the engine. For that reason, injecting the precise amount of water/methanol is not as important, privided the EGT is under control.
Manifold pressure in excess of 100psi requires (as mentioned by you) requires a machanically driven pump. Those application is only a small proportion to the norm. I think the market we willbe aiming for is the modern DI diesel where the PWM system will excel and gives good consistant results. I totally agree with your marklet analysis.
The DI tecnology has brought SI (spark ignition) and diesel enigne closer. Most SI/DI engines use the excess-air method for cruising and mid throttle by having the throttle plate fully open and use lamdba sensors to target afr.
Old 30-04-2012, 09:47 AM
I think that a second stage activation would be a good idea, although the gain might help in that area. The area under curve if you could increase power better than a PPS, and show lower flow might be a seller, or just easier to tune. I know that you mentioned problems with using map based injection while tuning rpm maps on EVOM or nabisco. It will take a bit to get oil burners to buy something more expensive than what they have, but MPG and dyno maps will probably sell it. Ability to start injection earlier to reduce fuel usage without flooding would be nice. Sending you a pm about something else.
Old 30-04-2012, 11:06 AM
The HFS-4 is basically a 2-stage controller.
Most OE diesel engines uses a small turbo for quicker spool-up reason. The HFS-4 will injection based on Boost first and followed by IDC. The addition input of rail pressure will further aid the water/fuel ratio accurancy.
I would leave the oil burners alone. I agree the PWM system is more suited for day to day modern diesels.
Old 03-05-2012, 03:35 PM
How would the failsafe be handled? I don't know how to trigger a failsafe for a diesel. The more boost at the same fueling the less EGTs. What would the failsafe trigger? Boost cut? Do modern diesels have a map switch?
On another note, I think that dynamic range would be a good selling point for bigger diesels.
Old 04-05-2012, 07:43 AM
I have not worked on the diesel failsafe yet, It willnot be easy to interrupt a mechanical fuel enrichment component. The modern diecesl may be easier, just reduce the throttle angle sensor signal or foll the rail pressure sensor.
If we were to introduce a diesel system, it will be for the Di-common rail trype diesels.
Old 11-05-2012, 12:44 PM
How about an HFS2v2? All the features, minus the failsafe. Post some flow differences, that might help.
Old 12-05-2012, 04:42 PM
The HFS2-v2 is well priced and will perform all the functions of the H3 and H4.
I am not sure which market to target, performance, enconomy or tolling. Do you know which is the most common?
