Old 15-01-2013, 04:39 PM
brightside brightside is offline
Default Re: BMW Mini-R56 USDM wiring
It that a typo on the website? Just from the scale of things it does look to be 3/8 BSP.
Old 15-01-2013, 07:13 PM
All the aquamist HFS-xxx pump with 3/8BSP-M to 1/8BSP-F adaptor as standard.
Adding this fitting will make the joint very flexible.
Old 17-01-2013, 04:08 AM
Ah, ok. This is what happens when you take 8 months to complete the install.
Should i order from you or Jeff?
i'll also start a thread about my install. Waiting for my gauge mount also now.
Old 17-01-2013, 08:48 AM
It is completely up to you. If you have been dealing with Jeff before, you can continue. I am here for your technical support regardless.
Old 24-03-2013, 04:25 PM
hor_fun hor_fun is offline
Hi richard
Any updates for n18 to use hfs4 or hfs3?
Wanting to use your products on my mini.
I looked into this briefly. The N18 DME is still made by Siemens I cannot verify the the pin out compatibility.
N14 Engine - N14B16AC (171hp / 177 ft-lbs)
* infinitely variable single VANOS (intake only)
* Siemens DME MED17.2 engine management
N18 Engine - N18B16M0 (181hp / 191 ft-lbs)
* infinitely variable double VANOS
* map-controlled oil pump
* variable valve timing (Valvetronic) with 3-phase servomotor and integrated eccentric shaft sensor
* composite camshaft construction
* new piston design
* Siemens DME MEVD17.2.2
Old 25-03-2013, 11:39 PM
Both H3 and H4 will work on the new mini. I just don't have the DME pin out details to make a drawing.
I believe they will be the same.
Old 12-04-2013, 03:25 AM
Diego9 Diego9 is offline
I just have it installed in a GP2, so it will work in N18 engines. Now I need to learn how to set it up and read the gauge.
Old 12-04-2013, 07:37 PM
This is good news. I was unable to get the new mini DME pinout. Now I don't have to. Thanks for the update.
