Old 04-08-2015, 06:57 PM
upnorthstar upnorthstar is offline
Default diagram for Dodge Charger Hellcat?
Hey Richard; I plan to install an HKS-3 on my 2015 Charger Hellcat...does it matter if I splice at the actual injector or tap into the appropriate pins at the Powertrain Control Module ? diagram link below...
I am also torn on whether to use the MAP signal instead of IDC...any obvious preferences with a positive displacement supercharger setup...?
http://www.aquamist.co.uk/vbulletin/...1&d=1438710982
thanks for your help
Old 05-08-2015, 05:00 PM
Default Re: diagram for Dodge Charger Hellcat?
It is easier to tap from the fuel injector, Red and green wire of the grey harness to the fuel injector.
Is there a map sensor in the drawing? I canlt seem to fine it, Do you have a higher solution diagram, it is not easy to read.
