Old 17-03-2016, 09:41 PM
Maktech Maktech is offline
Default Re: Help please,HFS 4 V3 wiring diagram for E63 AMG
By the way we use one jet , could you describe me how to modify the circuit for one jet ?
Old 17-03-2016, 10:11 PM
Originally Posted by Maktech View Post
We are using only the red wire of grey conncetor for 12V
Good, That is all you need to d on the grey wire.
Old 17-03-2016, 10:12 PM
What size?
Old 17-03-2016, 10:21 PM
What size?
The 550cc one
Old 17-03-2016, 10:32 PM
You don't need to make any circuit change with that.
Old 18-03-2016, 12:54 PM
Thanks for the support.
we cut the thin wire between at C ,
And also we change the position of a jumper ;
The system is okay , now
Old 18-03-2016, 06:22 PM
According to our record, your system was shipped to someone in Bulgaria. It was April last year, It took almost a year. Some solder configurations were incorrect, it was not done At aquamist. You friend was not telling the truth. It could not be brand new.
You have one more solder mods. The MPS "2" link has to either be cut or unsolder "3".
Old 18-03-2016, 08:03 PM
Yes , we made all modifications that you told me then we had another issue ,
The pump comed on at idle ; this time it was injecting water , too .
We changed the jumper IDC to MPS and the system is working without any problem.
I am sending you the last positions of the jumpers :
Old 18-03-2016, 11:32 PM
OK, so far so good.
Lets look into the IDC trigger problem.
I like to take some voltage reading on test pin #16 at:
1. pre-crank
2. idling
3. quick flip of the throttle.
Old 19-03-2016, 01:16 AM
Thumbs up Re: Help please,HFS 4 V3 wiring diagram for E63 AMG
OK, so far so good.
1. pre-crank
2. idling
I will measure it on monday
