Old 06-06-2018, 03:16 AM
SAMzG35 SAMzG35 is offline
Default Re: Nozzle size
I saw this on another forum for a VQ35 lower collector and i liked the idea. When you mentioned the distribution block I thought that might be a better way of doing it. But now you mention I need a check valve for each jet which complicates thing a bit more for me.
Old 06-06-2018, 03:19 AM
dlheman dlheman is offline
Originally Posted by SAMzG35 View Post
I'll check that thread. I think doing all this plumbing might be too much work for me with the time frame I'm working with. I might end up with 2 x 1.2+mm jets (750cc each) on the intercooler outlet and see how that plays out.
Sounds like a good plan. Let us know how you go!
Old 06-06-2018, 03:24 AM
The checkvalve is so whatever remains on the tubing don’t get vacuumed. *maybe* it is OK if the tubing is short as there won’t be much water in there anyway, so all you need is a single checkvalve before the distribution block. But I can’t remember if Aquamist have a check valve big enough for the bigger size tubing coming out of the FAV to the distribution block.
That being said, you can just use Devils Own checkvalve between the FAV and distribution block, if Aquamist don’t have one.
Old 06-06-2018, 03:30 AM
I was looking at the thread by Rice Racing and I dont think I see a check valve except on the inlet to the distribution block. What you think?
Old 06-06-2018, 04:09 AM
Yeah, there is no check valve except for the one to the intercooler
Old 06-06-2018, 08:09 AM
Mhmm any reason why at the intercooler and not between the FAV and distribution block?
Old 06-06-2018, 09:25 AM
These is a specific direct port custom kit, made for client bespoke to him by Richard to my design requirements to make the power I specified for a WM50 car. I use 'allot' of fluid and its seamless in delivery via the Life Racing F88 based ECU, any rpm any gear, 1 second from 4.5k to 8+k rpm perfect set up.
Jets for direct port engines listed here > http://www.aquamist-direct.com/806-5...-applications/
http://www.riceracing.com.au
RICESP > F40 > Zonda > ZR1
Water Injection Specialist
Old 06-06-2018, 03:33 PM
What? 1 second from 4.8K to 8k?
Good lord.
Old 06-06-2018, 11:46 PM
K I ordered the jets and fittings to do individual port injection. Let’s hope it’s here in time for tuning.
Old 19-06-2018, 01:19 AM
Got my kit from Aquamist fairly quick. They are awesome!
Some progress pictures
