Old 04-11-2004, 01:28 AM
Nenad Nenad is offline
Default Average water consumption
I am totaly new in this and recently bougth SC kit based on Eaton MP62 with 7,5 PSI of boost.
What is average water consumption in WI system? I presume that it should depend on SC/turbo boost, i.e. driving style, maybe size of engine.
In any case I would appreciate very much if you could give me some parmeters.
TIA
"They can order any color...as long as it is black"
H.F.
Old 04-11-2004, 01:55 AM
Macabre Macabre is offline
Hey Nenad.. this is for your Passat I presume?
I use about a half gallon of WI-fluid per tank of gas, of course depending on how I drive. It's a difficult question to answer precisely since it depends greatly on the design of your WI system, but a gallon sized resevior is common for street cars.
Or look at it this way... if you're running 6 440cc/min injectors @ 3bar @ 80% IDC at your horsepower peak, with 20% water/fuel ratio, you'll be pumping about 420cc/min of water, so you'd empty a 1 gallon resevior in about 9 minutes of max usage, so just figure out how much time you would spend at peak power during the course of a tank of gas. You'd empty your fuel tank in about 30 minutes giving that example.
Old 04-11-2004, 02:05 AM
Hi Mac,
thx for lightening answer.
Yes, it is for my SC. My injectors are RC 270cc/min at 3 bar.
Mr.Richard Lamb from Aquamist was kind enough to recommend 1S or 2D systems for my set up.
H.F.
