Old 08-03-2016, 09:30 PM
ray@Np ray@Np is offline
Default no green LED
i just finished installing the HFS-2/3.1 pwm in a 2004 silverado turbocharged and i do not have a green led flicker at start up. On the gray ecu connector i have the green wire going to the negative trigger side of the injector and the red going to 12v ign. Any help would be appreciated
Old 08-03-2016, 10:58 PM
Default Re: no green LED
Is the engine running?
Old 08-03-2016, 11:45 PM
Yes sir i got it figured out, but still having an issue during testing, no fluid is coming out the other side of the flow meter i have double checked all my wring, pump is turning on and fluid come out of the feed line to the valve but nothing comes out the other end
Old 09-03-2016, 07:26 AM
How did you do the flow test?
