Old 22-08-2011, 08:40 PM
infinkc infinkc is offline
Default What size flow restrictor? dual 0.8 nozzles?
i couldn't find much on what size flow restrictor to use, i am running dual .08 nozzles. kit is a hfs5, but i would think things haven't changed that much.
Old 22-08-2011, 09:47 PM
Default Re: What size flow restrictor? dual 0.8 nozzles?
You can leave the restrictor out if you are running two 0.8mm.
Old 22-08-2011, 10:49 PM
thanks Richard, also any chances of getting a separate hfs1/5(retired systems) sub forum for questions? or is that system not supported anymore.
Old 23-08-2011, 08:03 AM
It is normally supported on the general aquamist below the HFS-xxx. Parts are becoming more difficult to find as the some spares have run out. If there is a need for another forum, I will certainly create one.
