Diff. in tuning a 15wt%MeOH-water Vs. 50Wt%MeOH-water mix
15/85 mix:
got to lean out fuel to burn hotTER due to high in-cylinder cooling 50/50 mix: got to lean out fuel due to the addition of more fuel/MeOH What about the timing and boost? The car is a 2.0L turbocharged mitsu evo. just want to narrow it to either 15/85 OR 50/50 wt%. Please help. Btw, the 15/85 mixture was chosen because the surface tension of water is very much reduced (effect tapers off as wt% MeOH increases) and I'm hoping that it will lead to better atomization and better distribution of water to each cylinder. |
It is possible to take some picture to show the difference of the two mix?
the decision is based on the paper titled :"Quantitative assessment to the structural basis of water repellency in natural and technical surfaces" - Journal of Experimental Botany, Vol. 54, No. 385, pp. 1-9, April 2003
Surface tension of: 100% water = 73.5 dyne/cm 10wt% MeOH in water = 55 dyne/cm 20wt% MeOH in water = 47.5 dyne/cm 50wt% MeOH in water = 34 dyne/cm 100% MeOH = 23.5 dyne/cm factors affecting atomization: surface tension, density and pressure @10wt% MeOH, surface tension of water drops 25% @20%, 35.4% I am trying to stay away from/use as little methanol as I can because there is already enough fuel from the injectors, and replacing gasoline with alcohol makes no sense (less heat of combustion from methanol). Also added cost for buying MeOH. |
I will once i get all the fittings in for the system.
i actually have a shurflo 100psi pump sitting around......just need to get from a 3/8MNPT to 4mm to use the aquamist nozzles
I try to make sense of this, does higher surface tension gives better atomisation?
Richard |
GotH20 was kind enough to send me a copy of that graph, which I stuck on my website (thanks mate :wink: ) It confirms my experimental data that most of the surface tension benefits have been achieved by 20%. Given the increased safety of such a mixture, I tend to stick with it, as a good compromise |
