Old 25-09-2010, 08:14 PM
Default Porsche 996TT
Old 04-02-2011, 12:20 AM
Milou911 Milou911 is offline
Default Re: Porsche 996TT
Does this represent the 997 also? I'm trying to install the hsf3 on my 997.1
thank you
Old 05-02-2011, 02:32 PM
WhiteKnight WhiteKnight is offline
Hello Milou,
You can use this diagram also for 997tt.
I did not wire the failsafe boost cut cables because VTG solenoids work differently than 996tt boost control system.
Emre
Old 08-02-2011, 06:24 PM
Thank you Emre
Old 08-02-2011, 10:44 PM
thank you Richard
Old 06-05-2011, 04:33 AM
Slvr-GTstreet Slvr-GTstreet is offline
I want to tap from ecu.. and I know it's one of the green wires but which one is it?
Old 07-05-2011, 11:06 AM
I am not sure what the queston is, there is only one green wire on the grey connector.
Old 10-05-2011, 09:06 AM
Just to let you know that this diagram did not work for me. It shows that the green wire to the brown/black F.IDC which flooded my engine with gas. Then a friend suggested to tap the green wire to Brown/Green and now it all seems Ok.
Old 11-05-2011, 11:28 AM
This is interesting, I will check against my 996 files. Thanks for the update. Psot some install pictures if you can.
Old 24-07-2011, 06:52 AM
So far I was running 100% methanol, I Decited to shift to 70/30 methanol/water to keep it safer. I was told that this is the highest % of methanol that can be used and not be flammable and catastrophic in case of leak.
I have Decited to run 70/30 but I think the sprayers supplied does not support the needs of my engine.
I have it set at 09:30 and 5,00 which is the maximum %.
Anyone who has seething to share on 997 turbo application?
Thx Antonis
