Old 11-02-2011, 10:04 AM
Ryan23 Ryan23 is offline
Default Controlling FAV via standalone
Hello -
I've got a 00' Impreza STi and am currently running a HFS-3. I've since swapped out the ECU from a Power FC to a full Link G4 standalone. In the interest of integrating everything, I'd like to drive my FAV with one of my spare PWM Aux outputs on the Link. I can then map out secondary fuel/timing map and integrate my fail-safes. What frequency should I set the FAV channel at? I can go from 10-300hz via the Link. I did a search and found a recommended setting for the older HSV but I'm not sure if the newer FAV would be operated at the same rate.
Thanks in advance!
Ryan
Old 13-02-2011, 07:17 PM
Default Re: Controlling FAV via standalone
we always recommend running 30Hz. We cannot advise more details how we drive the FAV under various custom configurations.
Old 14-02-2011, 03:48 AM
That's all I needed, thanks!
