#21
i thought so too .... could there be a problem with your meth supplier?
Or maybe your container? When was the last time you cleaned your water filter?
Keep it real 93 Suzuki Swift Gti Turbo @15psi System 1s Microtech LT-8 ECU Hugh Gordon |
#22
The meth supplier is spot less. I am just gonna keep an eye on the situation.
I have just orderd some aquamist nozzels. i plan to run 2 x 0.8 jets but with this amount of flow i need to re think there placing. Any ideas ? Scott
RX7 |
#23
Fuel methanol I've purchased will develop a "snow" like deposit in suspension with the fluid after it sits for a while.
I have been led to believe it is a lubricant or scent they add to the fuel but am not sure. I saw it in my WI system on a couple of occasions. and started running a fuel filter in line with the lines to screen the crud out. Not sure it your seeing the effect of the same thing but just a thought. Have you tried putting a sample of your methanol in a clear jar and seeing what happens over time? Larry |
#24
Argh ... That makes sense. I thought i was crazy when it had a smell to it. Usually it doesnt.
What you describe sounds spot on. I have filtered the methanol into a plastic container and a glass container so i can see if there is any differance. Scott
RX7 |
