Old 03-05-2015, 06:09 PM
jdraps13 jdraps13 is offline
Default Re: Mazdaspeed 3
Hey Richard having troubles setting up my failsafe, seems to be spraying with next to no load, my sc is set at 6 bars I think wh is set properly but can't figure out how to set WL proper, how might I delay spray
Old 03-05-2015, 06:15 PM
What is the position of the "THRES" on the controller?
Old 03-05-2015, 06:25 PM
I followed the instructions and aet fully counter clockwise still
Old 03-05-2015, 07:07 PM
Fully counter-clockwise is for testing only. Set it to 10am and see if you can set the WL.
Old 03-05-2015, 09:39 PM
Ok so it's not spraying with every blimp of the throttle now but, still can't seem to get the lower failsafe to trip maybe my upper is set too high
Old 04-05-2015, 07:38 AM
What are the settings for the following:
(face of a clock)
THRES ....... ?
SC .............?
WL ............ ?
WH ..........?
Let me know.
Old 04-05-2015, 12:09 PM
Thresh 12am
Sc 2am
WL 1am
WH 11am
Old 04-05-2015, 02:27 PM
One last thing I was checking out the wiring and I am wondering if I set up 2AA wrong, For the wire that needed to be cut I used one posi lock with brown and 2AA connected to one end and white and 2AA to the other is that correct or should use two posi locks? One for brown and one end of 2AA and the other for white and 2AA so there is no more connection for 2AA, thanks Richard
Old 05-05-2015, 08:29 AM
Have you cut the 2AA wire into two halves?
Old 05-05-2015, 01:04 PM
Yes I sorted that out now use two posi locks instead of just the one lower limit failsafe is still giving me s hard time tho
