Old 09-10-2007, 11:29 AM
cosator cosator is offline
Default mixture for chargecooling
hi !
i want to use my 2d mainly for chargecooling as my intercooler might be a little bit to small for doing this job properly....
so what mixture (water/methanol) is best for chargecooling ?
thanks.
cosator
Old 16-10-2007, 06:22 PM
really no one......????
(yes, i?ve already done a search........ :wink: )
cosator
Old 16-10-2007, 09:47 PM
keithmac keithmac is offline
Well methanol evapourates quicker than water, but only absorbs half the heat. Methanol is a fuel so you`ll have to re-tune if you inject it.
Staring point for most people is a 50/50 water/methanol mix and go from there, what I`ve read on here is water is better as an anti detonant, but if you need to inject larger quantities it will "bog" the engine down.
Personally I run 75%meth 25% water at around 1.2l/min port injected and post turbo, this is on the high side and it took a bit of tuning to get it right.
Best bet is to experiment and see how you get on.
