Old 17-10-2016, 03:57 AM
Paulekas Paulekas is offline
Default Question about hfs-1
My system was fine until today it started acting weird every time i turn on ignition in on possition it starts spraying and flooding the engine when i start the car everything is fine? Its connected in pwm mode from injectors and sys on light is on when ignition is in on position What that could be ? Thank you
Old 17-10-2016, 04:33 PM
Default Re: Question about hfs-1
I measured voltage in prw wire seems like when ignition on pwr wire send +5v to the injectors seems like something got messed up meth controller box? Whats my option here? Test it or do you even sell new ones since its hfs 1 ?
I also tried connecting into mps mode still does them same seems like pwr and mps channels both sending 5v signal to the injectors
