Old 25-08-2011, 03:00 PM
sebdut sebdut is offline
Default Re: HFS-3 in porsche 997TT
It seems to be the same problem of me
Old 25-08-2011, 07:09 PM
ysfg35 ysfg35 is offline
i found another source for 12v to power the system .. so the gauge lighting issue resolved .. now once i turn the car off , gauge turn off too !!!! but pump still not working ..
the aquamist came with ground kit , for pump ground wire !!! is it necessary to use i??? because i did not use it .. i just wired the black wire to chassie .. so is it possible that this is the reason why pump not working ??
Old 25-08-2011, 07:46 PM
This is good, do you have a pinout for it? May be you got it from the fuse box?
I wonder if it is the relay?
If you use "SYS" to turn on the pump relay (with "FAV" unpluged). Let me know if you can measure a 12V across the pump. If the ground is bad, you will not see a 12V across the pump connector.
Old 26-08-2011, 10:19 AM
dear richard , my friend just came to check the pump wiring , and oooops the 12v supply was connected to bettery ground terminal by mistake from me loool
pump now is working perfectly.
today i will do the tuning and give you an update.
thanks
Old 26-08-2011, 11:30 AM
I didn't pick this up from the pictures you posted.
Thanks for the update, good new indeed.
Old 27-08-2011, 09:05 AM
Everything fine , tested the sray by useing the SYS in the controller , than i tested the system by active the F-IDC and everythings perfect ..
richard when i tested the system by SYS it showed me 3bars in the gauge , after that i went to road real test and it showed me in the gauge 4bars only ... so is that mean that system is spraying full flow that i need ?? more info will be usefull .. thanks
Old 27-08-2011, 05:02 PM
Now is a good time to set the gauge to display 5-6 bars at WOT and high RPM. (using the "SC" trimmer on the gauge).
