#51
TeeJay (OverBoostinBimmers) Einy, Meany, Mieny, MO: 08 Mitsubishi Evolution X GSR 08 BMW E90 335i 09 BMW E82 135i |
#52
This is only done recently. There will be more to come once the GB shipping is over, at present, there isn't enough time in a day to do everything. I will be generation more internal sub forums for individual cars so users can download and discuss their particular car and ECU.
#53
There has been some confusion on what type of direct injection signal the HFS-3 can read.
The HFS-3 will be only able to read directly injection signal if it is re-configured by aquamist or selected dealers. It the system is not ocnfigured properly, it will not work. For those of you who want configure the system yourselves (soldering iron required), please contact me at richard@aquamist.co.uk. I need to know the car model and year of manufacture. It can all be done, but there isn't a "one size fits all" because there are so many types of direct injerction system around. This applies to diesel and gasoline engines. Richard
#54
I plan to run 50/50 with boost of 21-22psi. My injectors are 860cc, but do I take into account their max duty cycle or calculate based on their potential?
4 injectors x 860 = 3440 x 0.15 (50/50 ratio) = 516. So looking at the chart I should run either the 1.0mm or 0.9mm jet with the 0.7mm restrictor? |
#55
Your calculation is correct. The duty cycle is relative, so if your injectors are at 80%, so is the Aquamist. Therefore we usually go by injector size and disregard duty cycle unless there are some special circumstances or the injectors are oversize and max out at 55-50%
#56
Perfect...when I was logging I was topping out at 76-78% IDC
#57
The HFS-3 is equipped wioth a gain trimmer, you can always use it to do fine adjustment. I would oversize the jets and turn the flow up or down with this trimmer.
Picking the exact jet is not as critical.
#59
yeah thats what i initially thought... thanks for clearning up Richard. another silly question, how do i workout that what trims i need to put... do i use the excel spreadsheet??
#60
The "THRES" trimmer is set for 42% IDC (12 o'clock) from factory. It may be a big too high for you due to your large injectors. I would set it to 9 o'clock, ~24% DC.
The "GAIN" remains the same - see how it goes from there. Jeff's spread sheet is very good, you can use it to estimate your flow based on the jet/jets used.
