Old 05-04-2016, 09:13 PM
Iguanapeluda Iguanapeluda is offline
Default Re: Direct Port EVO IX rs HFS3
Originally Posted by Flr Power View Post
Don't use these clamps with boost.
T-BOLT Is better?
Old 05-04-2016, 09:27 PM
Originally Posted by Iguanapeluda View Post
T-BOLT Is better?
Yes you will need them for high boost.
Old 26-04-2016, 11:19 PM
Well,
A upgrade of my proyect...I think the place of the FAV and the 4 way manifold...
What do you think for the place?
thank you.
Old 30-06-2016, 10:58 AM
Well...
I this friday I will tune my ecu with water/meth...
https://youtu.be/vhUKnBiXf-I
I am scary with this quantity of water.
Note...I canīt preview the video..
Old 30-06-2016, 11:19 PM
jbailey jbailey is offline
This is incorrect. I have NEVER needed t-bolts on cars that we're running 30+psi on.
T-bolts do not provide even clamping force around the entire surface of the band. You also run the risk of over-tightening and collapsing the pipes.
Normal worm gear clamps work excellent. Turbosmart also makes a constant tension clamp that you can use if you're having issues holding normal clamps on.
Old 30-06-2016, 11:23 PM
Well...
Beautiful atomization!
Why are you scared regarding the quantity of water?
