Old 19-05-2016, 02:35 AM
msp1609 msp1609 is offline
Default Ecoboost Mustang
Is there any possibility of getting a wiring diagram for a Ecoboost Mustang using a HFS-3. I have a kit that is currently setup for a mazdaspeed 3 ecu is there any re soldering of the board required?
Old 19-05-2016, 07:12 AM
Default Re: Ecoboost Mustang
I do not have a factory wiring diagram for the engine. If you can send me one, I will make a drawing for you.
I believe the engine is 2.3L turboed and direct injection?
Old 19-05-2016, 11:32 AM
Yes it is also a 2.3L direct injection motor. The mustang 2.3 is actually based on the 2.3 in the mazdaspeed. I am working on getting a pin out for it.
Old 20-05-2016, 02:08 PM
I believe this is what you need. I was able to find all the sensors in the mazdaspeed diagram. I had to upload it to my personal ftp as I couldn't attach it to the site.
https://onedrive.live.com/redir?resi...int=file%2cpdf
Thanks!
Old 21-05-2016, 09:28 AM
This is great.
In order to make a proper drawing, I also the outline of the ECM, can you help? A clear photo will also work.
Old 21-05-2016, 10:07 AM
This one close?
Old 22-05-2016, 12:46 AM
From the photo's i've looked at this is what i came up with.
EDIT: Just went and popped my own ecu connector off and can verify that it is the connector in the photo i attached
Old 22-05-2016, 09:23 AM
Looked like the ECU of the ecoboost of the Focus st is not the same. Can you tell me where pin #1 is?
Old 22-05-2016, 01:18 PM
Rich i've marked both pin #1's in this photo. Had to zoom in on the photo to read the stamping
Old 22-05-2016, 05:49 PM
Thank you for the update. I should be able to make the drawing an post it here in the next few days.
