Go Back   waterinjection.info > Aquamist specific system Q and A and new products > Aquamist systems in details and latest offerings
Old 30-07-2014, 04:35 PM
Default Re: New water tank system
Originally Posted by Pit Viper View Post
I think it's a great solution. Considering the thinness, it also wouldn't take much modification to stack a few side-by-side if you needed added capacity.
This planned already but we have not solved the unequal height caused the protruding bolt head if a water pump is assembled below. There will be a height difference of ~2mm. May be the rounded bottom of the tank wall provides a perfect solution.
We will supply four double length acetal stand-offs and four longer bolts.
Old 30-07-2014, 05:25 PM
Richard, are the caps vented like the Howerton Engineering tanks are?
The cap has a label with instruction regarding venting. Cap is not vented from factory.
Old 01-08-2014, 07:30 PM
Dust Dust is offline
From
http://www.aquamist-direct.com/806-6...-version-only/
The bracket is ergonomically designed to minimise installation time. Offering chassis floor or cross-rail mounting options. Four holes at the centre section of the bracket is intended for mounting an aquatec pump below.
Old 01-08-2014, 09:42 PM
Uses little space...
Old 03-08-2014, 07:17 AM
blue blue is offline
I'm thinking out loud here
Will need to check for space but thinking I could also use this as a buddy tank
For my existing howerton mini r53 boot install, perhaps mounting direct to the outside wall
Sound possible for a retro fit?
blue
Old 03-08-2014, 08:11 AM
Outside wall?
The tank is 13" x 13" x 2.6", check the side panel of the boot.
Here is a trial fit to a smart car:
Old 03-08-2014, 08:26 AM
http://howertonengineering.com/mini/
Using outside facing sheet metal as the fixing point.
The sloping seat back is the challenge on a r53
Will be a very tight fit,
Might work if on slight angle or offset say -10 degrees from vertical
blue
Old 03-08-2014, 09:12 AM
I have emailed you and jeff some pics of my mock up
Will be better than a thousand words here
As was struggling to resize on iPad
blue
