Old 15-08-2010, 12:52 AM
cammy cammy is offline
Default Re: Aquamist HFS-3 system for 2010 ..... "Q and A"
Hey guys
Quick Q about wiring in the HFS-3 to an EVO 7 JDM ECU. In the Diagram it shows a red, green and a pink wire to go in to the ECU harness. However the RJ-45 cable supplied does not have a pink wire which one am I supposed to connect to pin 42 for the +alt map switch.
Old 15-08-2010, 10:05 AM
daymean daymean is offline
^^^I think the orangy looking wire is the pink one....
I am installing my hfs3 in my evo8 atm and having some problems with getting the pump to prime...did it work well for you?
Old 15-08-2010, 02:16 PM
Originally Posted by cammy View Post
Hey guys
The latest version of the HFS3's pink map switch wire has been replaced by an orange wire, We may not hav euipdated all the diagrams on the user manual. The cable supplier decided to change it.
Our apology.
Old 16-08-2010, 02:23 AM
Richard :
lol, no apology needed the amount of help you provide is above and beyond and I am sure everyone appreciates it.
daymean :
Sorry mate, I have not tried to turn the system on yet as my engine is still not in the car. When its back in I will let you know
Also I will have lots of pics of the install.
Old 16-08-2010, 03:07 AM
Richard :
X2 both Richard and Jeff @ Howerton.
Old 25-08-2010, 11:49 AM
hey guys, back to bother you again
I finished the wiring for the control units power and I can only get the one LED to light up. Is this because I have not filled the tanks for the first time yet ? I am still putting the motor back in but all the sensors and wiring is done.
I read the manual and saw it should come on after 5-10 secs ? what am I missing
ಠ_ಠ 2001 EVOLUTION VII - 2.4L + AQUAMIST
Old 25-08-2010, 11:59 AM
Disconnect the water level sensor and try again.
The system will not start up if the tank is empty.
Old 25-08-2010, 10:42 PM
problem solved. thank you muchly
Old 30-08-2010, 03:35 PM
Hey Richard,
When setting up the Sensor calibration, should this be done with the jumpers in test mode, while the car is stationary?
Old 30-08-2010, 04:56 PM
It has to be done on the road to be certain.
I suggest 10 clicks on WL and WH from ZERO. Set the SC to 12 o'clock Let me knwo how many bar you are seeing with this setting.
Where are you located
