Old 08-04-2004, 11:58 AM
bus bus is offline
Default Water Tank Suppliers
I have a 92 Miata with WI that works well, but the mfg tank is too small. Anyone have any ideas where I can get a larger tank. I would like to get something that I can put in the trunk and have a low acholol / water sensor.tia
Old 08-04-2004, 10:46 PM
mx5 mx5 is offline
1 gallon gas container from your local autostore. Drill holes at the bottom in some small area and glue a small plastic canister there. Mount the pickup point to the canister. Then put this new tank behind the battery - between the battery and the tail light. You can use some brackets to hold it to the one of the bolts at the battery tray and add another one at the rear panel - just glue the brackets to the tank. Works perfect
