Old 24-05-2014, 11:52 AM
boukman boukman is offline
Default Pump fitting to tank
Hi,
On manual they say that pump has to be below tank.
Could you tell me if this setup is good or not?
Regards.
Old 24-05-2014, 12:28 PM
Default Re: Pump fitting to tank
Can the pump be rotated 180 degrees so the pump is gravity fed. Either way, it is fine if you are not to fussy.
Old 24-05-2014, 02:25 PM
I will rotate it, thank you!
Old 27-05-2014, 05:42 PM
Dust Dust is offline
Boukman, please take a pic. It looks to me that the fittings would hit the pump if it was rotated.
Old 27-05-2014, 07:04 PM
Hi,
You are right, I got fitting issues so I put pump on car floor.
Thank you
