Old 30-06-2012, 03:32 AM
ek9max ek9max is offline
Default Jets leaking!
Just finished up my install and ran some tests. Didn't leak during the tests.
Went for a short drive to make sure it was working all good. Got home and opened my engine back to see the very slightest bit of fluid.
I'm running 100% meth so I don't want to see anything, ever.
Is there a silicone or something like that I can use? or teflon tape of some sort?
Old 30-06-2012, 07:23 AM
Default Re: Jets leaking!
Where is the leak exactly?
When you install the jet adaptors, did you loctite them?
Old 30-06-2012, 08:17 PM
I didn't loctite them. It's on the Jet adapter to the intake.
I just read that I needed to. haha.
So I went out and got some high temp Permatex threadlocker, Permatex high temp thread sealer. Also got some Loctite 242 threadlocker.
Now which one do I use? Threadlocker or Thread sealant?
Old 30-06-2012, 11:18 PM
Anyone of the two will do.
Old 30-06-2012, 11:34 PM
There are three choices
Old 30-06-2012, 11:40 PM
Sorry, I didn't see the second being different from the third
OK, loctite 242 is something I have used before. I don't know enough about the other two to make a sound conclusion.
Old 30-06-2012, 11:47 PM
We use high temperature loctite for most of our work.
