Old 12-08-2015, 08:57 AM
M3GTttHulk M3GTttHulk is offline
Default Re: HFS-3 problem, Getting low water light
No failsafe light any more, but also I am only seeing 2-3 bars now on the guage in full boost.
Whats the next move?
Old 12-08-2015, 11:03 AM
Next move is:
why two bars only?
Did you see more bars before?
Old 13-08-2015, 10:55 AM
Next move is:
why two bars only?
Yes, quite a bit more back when the system was functioning, and before this failsafe problem started
Old 13-08-2015, 06:58 PM
It is the very usual for people to look elsewhere instead of checking for a semi-clogged jet.
We need to start from the basic and work up to the electronics, the most unlikely part to go wrong. The system is detect abnormal flow so look for the abnormal flow first...
1. clogged jet
2. clogged filter
3. kinked tubing
etc.
Old 16-08-2015, 11:48 AM
1. clogged jet
2. clogged filter
3. kinked tubing
etc.
1. I already replaced the jet with a new one I had, only one size smaller, so we can rule that one out.
2. Could be but I got a nice stream of water when I tested the pump
3. See #2
Funky,,
Old 17-08-2015, 07:14 PM
Yes, this is a difficult one.
What size jet are you using? If we can do a "one-minute on" test into a glass, it will help tracking down the cause.
Old 18-08-2015, 04:19 PM
0.9 jet at the moment.
I recently replaced both turbochargers, wodering if that is changing my Aquamist reaction
Maybe I should just up the "gain"?
Old 18-08-2015, 06:08 PM
Can you do a "1 minute on" test with the 0.9mm jet before moving on, otherwise we never we never get to the bottom of this.
Old 19-08-2015, 07:40 AM
I will try to do it this weekend.
