Old 12-09-2012, 04:11 PM
Default Re: Install HFS-3 on DI engines - any need to connect MAP sensor?
I have sent the flow table reflash instructions.
Old 16-09-2012, 05:39 PM
Cptn_Sol Cptn_Sol is offline
Ok, i'll try to find the way to make reflashing...
ps: i've posted photos of my install:
http://www.aquamist.co.uk/vbulletin/...ead.php?t=2324
Old 16-09-2012, 07:18 PM
Very nice and clean install.
Once you have made a flash cable, I will send you the files to modify the flow table. I have five to six to suit every jet combination.
Old 27-09-2012, 08:45 PM
Exclamation Re: Install HFS-3 on DI engines - any need to connect MAP sensor?
Hello Richard! I have a question about gauge workout.
In SYS mode (at full flow) it shows 2 bar lights.
When accelerating and 1 and 2 gears i see this:
http://www.youtube.com/watch?v=QAKGqIaa2_I
At 3rd gear:
http://www.youtube.com/watch?v=wGKeyseNPwA
At other 4-6 gears i saw 2 lights at full throttle.
What is it? On the 1 and 2nd gear flow is greater or what?..
Old 28-09-2012, 08:08 AM
I believe you need to flash in a flow table for a smaller flow. As I remembered you are only running a 0.5mm jet. The standard fl;ow table is cater for 0.8 to 0.1mm.
Until we have it reflashed, it is not easy to determine the actual flow with 2 bar resolution. The HFS-3 tracks fuel flow, your display probably shows what the injector is doing.
You can make the following test for me.
test pin 16:
(what the H3 is seeing)
1. at idle
2. at cruising
3. at WOT
Old 10-10-2012, 11:23 PM
softic softic is offline
Richard, which programmer should I use to re-flash the EEPROM?
Should it be PIC-specific programmer device or any SPI device is okay?
Can I just build SPI programmer on my Arduino microprocessor board and use it?
Also, should I unsolder the EEPROM from the mainboard?
Sorry for so many questions, but I will do the re-flash for Sergey (Cptn_Sol) and need to know more details.
Alexey K.
I drive Peugeot 207 RC 225 bhp with HFS-3 onboard / tuned ECU
Old 11-10-2012, 12:36 AM
I will pm you the details.
Old 11-10-2012, 03:21 PM
Richard, thanks!!
Alexey K.
Old 11-10-2012, 08:42 PM
Just a thought, I posted all the details to Cptn_Sol. I cannot find the email I sent. Can you ask him to forward the same email I sent him?
Old 12-10-2012, 08:22 AM
ok, will ask him!
so the question about SPI programmer was already discussed as well?
Alexey K.
