Old 07-11-2013, 11:46 PM
Mburns212 Mburns212 is offline
Default Which kit for a '02 330d
Hi,
Which kit would be best for a 330d. It is remapped, bigger intercooler, and straight thru exhaust around 230bhp at the min. I am not bothered about a failsafe as the car will be left in its current state of tune. How will I wire it in and which was would be best to activate it.
Old 08-11-2013, 08:12 AM
Default Re: Which kit for a '02 330d
Anyone of the HFS kits will work. The HFS4 is more suited for DI engine.
Old 08-11-2013, 03:36 PM
Thanks for the fast reply. Does the nozzle sizing guide apply for diesels as well? And will the pre-injection amount affect the duty cycle?
Old 21-12-2013, 10:38 PM
So sorry for the late reply.
As long as you are running water, you can use the same guidance as the gasoline engine. With the addition of methanol, it will modify the dieseling point, too much methanol and
cause pre-ignition.
You need to explain the second question.
