Old 01-03-2016, 11:02 PM
boostsys boostsys is offline
Default FAV not working from controller
Hi, I need help.
Recently I have installed new Aquamist HFS-3 kit to Subaru Sti and started system testing according to manual. But testing the spray pattern of the jets have failed, FAV doesn't work.
Test "Priming and purging of the system" is ok.
Harnesses are switched correctly.
At the gray harness green wire switched to injector "-", red wire switched to injector "+".
When I put 12V across the two parallel prongs of FAV coil it works.
Old 01-03-2016, 11:16 PM
Default Re: FAV not working from controller
Can you post a picture of the controller, a nice hi-res, in focus picture. I like to see the programming pin on the right hand side of the board.
Old 01-03-2016, 11:31 PM
Now I have only this photo.
Old 01-03-2016, 11:49 PM
When you tested the system, what jumper did you use to link the SYS?
Old 01-03-2016, 11:52 PM
I used PRK jumper to SYS
Old 02-03-2016, 12:00 AM
The jumper link remained on the FAV?
Old 02-03-2016, 12:05 AM
Yes, jumper link remained on the FAV
Old 02-03-2016, 12:07 AM
Good.
Do you have a digital voltmeter?
Old 02-03-2016, 12:09 AM
Good.
Yes, I have multimeter.
Old 02-03-2016, 12:11 AM
Great. Can you unplug the red harness and measure the resistance of the two outer pins (red and black).
