#21
Re: FAV not working from controller
Where did you measure the 13.5ohm from?
#22
Given up?
I suspect the cable is damaged.
#23
When I opened FAV connector one of the wire was damaged, they are very thin. I will solder it and will look on.
I'm measured 13.5 Ohms by cheap Chinese multimeter, maybe that's the point? |
#24
I have soldered wire. Now between red and black pins resistance 13.5 Ohms.
But testing the spray pattern of the jets steel have been failing, FAV doesn't work. |
#25
We are making progress.
Can you send a picture of your repaired location.
#26
I have had someone calling me this afternoon regarding purchasing a HFS3 controller, was it related to you?
#27
Now I have nothing to make photo with.
Yes, there was a telephone call to you from us. |
#28
Can you describe how the red cable got damaged?
I like to move on and and make some tests to establish the signal to the FAV is working, using the DVM you have. Make sure the FAV is connected. 1. Measure the voltage of pin 1 with the system on. (should be 12V) 2. Link SYS 3. Measure the voltage at the same place again. It should be OV I wait for you results.
#29
I gathered you have ordered a new controller. I hope this will solved the problem. If there is a short circuit on the cable it can easily damage the driver transistor. Please check the damaged cable is repaired properly and well insulated against the environment.
Can you explain how the cable got damaged?
Thread Tools | |
Display Modes | |
