Failsafe, and some other questions.
Hey guys!
I've been lurking about this forum for a little and wanted to join up as I've recently been having some odd things going on with my HFS3 kit. I have a 2002 Audi S4 Avant and I have reason to believe that the system is tripping a failsafe, and I cannot figure out why. (This system always just worked, I never had to do anything with it.) I thought at first it was the FAV, so I re-tightened it up, and it seemed to be working. But recently, I've been seeing both the 'level' light and the injection (upper yellow) light come on, sometimes one, sometimes both. Does the mounting orientation affect things with the pump? I'm really looking for a place to start troubleshooting. The methanol DOES spray when I do a system test, but in the interest of full disclosure, it's not a nice cone-shaped mist, but rather somewhat of a stream, which is disconcerting. Any help would be great. Thanks. |
Re: Failsafe, and some other questions.
Good thing the system has detected an abnormal flow.
Here are a list of things to check: 1. In-tank filter particially clogged 2. the pump's bypass valve may need readjusting, The internal spring can get weak after a while. 1/4 on the allen screw on the front of the pump normally cures it. Where is the pump located?
Pump is located in the trunk area. It's not mounted vertical though (hoses on the bottom), it's mounted sideways. Does that make a difference?
Can I pull the actual nozzles out if the pipe and try testing them again? I THINK I may have just had the tunes without the nozzles attached.
1/4 turn CW or CCW on the front of the pump?
Lastly (as I realized we're on vastly different time zones, so I want to give/get all the info I can between replies), is/should the flow sensor on the FAV be permanently attached TO the FAV? Currently, mine is just clipped on but not permanently attached. There's some kind of [what looks like] resin/epoxy under it.
Thanks for the replies. I'll shut up til I hear back. |
Can you send a picture of the FAV with the clip attached, I am not 100% understood your description.
1/4 CW to increase pressure I need you to do some of the checks I mentioned earlier. The conversation is too scattered for me to focus on your issue.
Richard! Thank you so much for the quick replies. Sorry I've scattered the thread. I will adjust the pump tonight once I get home to my tools.
here's the photos: FAV, CLIP OFF: FAV, CLIP ON: IN-TANK FILTER: PUMP ORIENTATION: Last edited by SpoolinB; 14-08-2015 at 10:06 PM. |
Any thoughts on this, Richard?
So I gave the pump a 1/4 turn, and it seems to fail safe less but it's still tripping the fail safe. Seems to hit the low water light first (which is odd on a full tank), and then I'll see the "W.Injection" light on momentarily, and then things will flow, kinda. It still DOES flow, but something is definitely off.
I'm having the car smoked for both a boost and vac leak tomorrow, I dont know if that has anything to do with it. Thoughts? |
