Old 18-02-2023, 08:12 PM
remski remski is offline
Default Definition of the restrictor.
Hi.
I've read the manual and it mentions "nearest larger restrictor to regulate the fluid flow so the delivery will be linear to the duty cycle".
What will happen if each restrictor is used (0.5mm,0.7mm,0.9mm, no restrictor) if total flow is 1100cc.
What will it change exactly.
My setup:
4x220cc direct nozzles
200 psi working pressure (with 4 nozzles)
4x1000cc injectors
50/50 mix
Standalone controlled table for the WMI injection. (controling IDC)
(want to add a charge pipe nozzle 0.7mm)
What I am trying to achieve is lower my cc output from my nozzles but keep the pressure thus the spray pattern.
When the system kicks in.. the FAV starts pulsating.. about 2-3 cycles/s.
Assuming (my nozzles 4x220cc) at that point are delivering 150cc/min .
What I want is FAV pulsating 10 cycles/s and delivering 150cc/min.
Can this be done with restrictors.
Remski
Old 24-02-2023, 05:57 PM
Default Re: Definition of the restrictor.
Nobody has any clue ?
