Old 28-05-2012, 03:15 PM
crum86 crum86 is offline
Default New Install On VL Turbo
I've just bought a hfs-3 kit to install on my RB30 powered VL Turbo. I'm planning on putting the injectors post intercooler. Just wondering where the best position would be. I was thinking in the top side of the 90deg bend coming off the cooler. I've included a pic showing the piping.
Its currently making a shade over 300rwkw through an auto and big converter and using the injector size calculator I've come up with 2 x 1.0mm nozzles. Injectors are 750cc. Does this sound about right for something which should make close to 600 flywheel hp with the w/m kit installed?
Old 01-06-2012, 02:04 AM
Howerton Engineering
Default Re: New Install On VL Turbo
That looks like quite the setup. Yes, two 1.0mm jets sounds like a good starting point based on the injectors and the HP level. Putting the jets at the exit of the IC looks to be the best position from the picture.
Old 07-06-2012, 08:26 AM
Another quick question. Is there a maximum distance that the FAV can be installed from the actual nozzles?
Old 07-06-2012, 02:53 PM
The closer the better. There's no set rule, but it does make a difference.
