Old 09-07-2006, 08:28 PM
TurboGTi TurboGTi is offline
i thought so too .... could there be a problem with your meth supplier?
Or maybe your container?
When was the last time you cleaned your water filter?
Keep it real
Microtech LT-8 ECU
Hugh Gordon
Old 10-07-2006, 10:49 PM
sdminus sdminus is offline
The meth supplier is spot less. I am just gonna keep an eye on the situation.
I have just orderd some aquamist nozzels. i plan to run 2 x 0.8 jets but with this amount of flow i need to re think there placing.
Any ideas ?
Scott
RX7
Old 11-07-2006, 03:07 AM
Fuel methanol I've purchased will develop a "snow" like deposit in suspension with the fluid after it sits for a while.
I have been led to believe it is a lubricant or scent they add to the fuel but am not sure. I saw it in my WI system on a couple of occasions.
and started running a fuel filter in line with the lines to screen the crud out.
Not sure it your seeing the effect of the same thing but just a thought.
Have you tried putting a sample of your methanol in a clear jar and seeing what happens over time?
Old 11-07-2006, 06:36 PM
Argh ... That makes sense. I thought i was crazy when it had a smell to it. Usually it doesnt.
What you describe sounds spot on. I have filtered the methanol into a plastic container and a glass container so i can see if there is any differance.
Scott
RX7
