Old 21-02-2006, 09:06 PM
ashtal ashtal is offline
Default ASTRA COUPE TURBO, DDS3, 1S KIT
ASTRA COUPE TURBO
Old 22-02-2006, 04:43 AM
mrex180 mrex180 is offline
The temp gauge you have in between your DDS3 and Boost gauge whats that measuring? And how much was your DDS3 worth? And i like your water tank in the boot too!
Andy
Old 22-02-2006, 06:10 PM
Andy
At the time of the pic it was the the temp of my garage, i was bloody cold ! Its now in the inlet track so i can see my inlet temps. Got my dds3 for ?150, bargain. :wink:
There is still the jet in the inlet pipe to fit so i will take a pic when i get it back !
ASTRA COUPE TURBO
Old 22-02-2006, 08:25 PM
Is there anyway to test all of the systems ?
ASTRA COUPE TURBO
Old 23-02-2006, 11:33 PM
Very neat install. Thanks for posting the pictures.
You can test the system by clipping the jet on the screen, over next few days, it can be used as a windscreen de-icer if you put 50% methanol in a separate tank.
If you disconnect any one wire on the MPS (manifold pressure switch), you can activate the system by getting a normally closed push button.
Don't forget to fill you tank up with 25-50% methanol to avoid any damage to the water pump.
I saw the 43C on the dash gauge, was it measuring the heat soak on your intercooler exit pipe?
Old 24-02-2006, 02:06 AM
I think it's 4.3'c richard :smile: Ashtal how did you rig up that intake air temp display it looks very neat, i want to do the same thing myself..
Andy
Old 24-02-2006, 07:05 PM
The intake temp sensor is very simple, Two wires connected to the cig lighter and the sensor i put into the inlet track.
All i did was tape the sensor head to the metal pipe and fix the hose over it as normal. Courtenay sport sell them for the astra turbo, but they would work on any car.
ASTRA COUPE TURBO
Old 24-02-2006, 07:09 PM
Is the methanol a mast have ? I aint got round to gettin any yet !
It was 4.3 degrees, which was the temp in my garage when i was fitting the dds3 and 1s kit !
When should the priming pump kick in ? Dont think its working !
ASTRA COUPE TURBO
Old 24-02-2006, 07:24 PM
JohnA JohnA is offline
Regarding the location of the pump -----> doesn't it get full of water in that place if the car is parked in the rain? All the water coming down from the windscreen ends up there, doesn't it?
John
www.max-boost.co.uk
Old 24-02-2006, 07:35 PM
It does, but the pump is raised to a piece of alloy and so is the flow sensor. I even put some rubber grommets beteen the pump and bracket to reduce vibration !
Sorry its a bad pic, had a new camera phone that day !
ASTRA COUPE TURBO
