Old 22-12-2005, 12:39 AM
bwhinnen bwhinnen is offline
Default Jet size questions - WRX
I've used the 'lovely' PHPBB search facility and have found a few entries of the jet sizes people are using...
But is there a specific formula to use, I understand that 10 - 15% of the fuel used is the guideline, but given that the fuel used across the entire rev range will be different is it a compromise?
I run 4 x 700cc injectors at about 68% IDC (@ 7000rpm), currently around the 199kW @ the wheels mark.
Currently I'm using the 0.5mm jet in a 1S system but would like to know if running a 0.7mm jet as a few others are using would be a better solution.
Jet location is in my FMIC piping, about 700mm before the TB.
Cheers and thanks
Brett
Old 07-01-2006, 03:11 PM
Default Re: Jet size questions - WRX
Cheers and thanks
Brett
In order to keeping the ratio relatively constant, you need to consider upgerading the 1s to a 2d system. The 2d tracks the fuel delivery and you can keep your w/f ratio much consistantly. If you need other ratios, just change the jet size.
Could you post some pictures ?
Old 13-01-2006, 10:33 AM
Hi Richard I'll grab some pictures as soon as I can.
I'll be looking at the 2d system when I get a chance, as well as upgrading from my current aftermarket engine management (a Link) to a Motec in the near future.
Cheers
Brett
Old 27-01-2006, 05:32 AM
Some pictures:
Jet Mounting.
Relative to the Throttle Body.
Another angle of the above.
Cheers
Brett
Old 30-01-2006, 07:42 PM
They are excellent pictures.
I just wonder if you can increase the methanol percentage since you are in the middle of summer months. 0.5mm for neat water and 0.7mm with 50W/50M mix to aid induction cooling.
Some pictures:
Jet Mounting.
Cheers
Brett
