Old 29-04-2016, 10:13 PM
FI_Rubicon FI_Rubicon is offline
Default Thank you Aquamist!
California rock crawler on the juice....
https://youtu.be/2NIWNk3Uf_0
Each one of those tires and bead locks is 37" tall and weighs over 100lbs. Jeeps are supposed to be slow.
Old 30-04-2016, 06:18 PM
Default Re: Thank you Aquamist!
Looked and sounded manic!
How much of a difference with the system on/off? M50/W50?
Old 01-05-2016, 04:51 PM
The rig weighs close to 5,350 lbs in the video (with the hard top off) plus the large diameter, heavy tires/wheels. There is also a heavy winch on the front bumper (drag racers keep the front end light).
Spraying 100% water 5-6 degrees of additional ignition advance. The power was noticeable and it just ran better overall.
With MW50, I am getting more like 7-8 degrees of advance over the tune for just the blower. Acceleration became a degree more "electrifying" with the meth.
I am being a little conservative and can probably go an additional degree in the mid and high RPM ranges.
