Old 12-05-2015, 07:21 PM
Default Re: Mazdaspeed 3
Which diagram did you follow and did you splice the injector signal pick up wire from the ECM or from the fuel injector?
I like to check your wiring.
Old 13-05-2015, 05:06 PM
jdraps13 jdraps13 is offline
I followed the mazdaspeed3 wire diagram v3
Old 13-05-2015, 07:08 PM
Can you send a link to the v3 diagram.
Old 13-05-2015, 10:10 PM
Here's the diagram, the only thing I soldered different on controller was 3 map instead of 2 cause I'm running big turbo
Old 13-05-2015, 11:01 PM
I am confused, which part of the diagram says v3?
Old 14-05-2015, 12:18 AM
Ok so I upped my thresh and everything is working awesome, delayed the duty cycle, failsafe is tripping it's good I think
Old 14-05-2015, 07:12 AM
Thanks for the update. Sorry I couldn't help much.
Old 17-08-2016, 08:50 PM
Puddin15 Puddin15 is offline
Do you have an updated wiring diagram for the HFS4-V3.1 for a 2008 Mazdaspeed 3?
Old 18-08-2016, 01:10 AM
Reason I ask is the HFS4-v3.1 manual calls for the red, green, and blue cables where the diagram on page 1 shows red, green, and yellow cables for the RJ48 connector.
Old 18-08-2016, 04:58 AM
I think I found the answer to my own question. Looks like page 20 (in the manual) shows the correct wire layout for DI applications which uses the yellow cable.
I did have a few questions on the jumper and solder settings though.
For the jumper settings, I believe all of the settings should be set to the default setting except the SET FAIL SAFE. I will be using an external trigger with a 5-12V input, so I believe this jumper should be set to FS1. Both CLP and FS0 jumpers can be removed. I will use the orange wire on the RJ48 connector and splice it with the external trigger of the boost control device.
For the solder settings, I plan to use the following settings:
AUX INPUT: default
IDC PRE-SCALER: x2.5 for DI
MAP SENSOR TYPE: 2.5 bar MAP sensor so I believe I need to solder link 2
FLOW SENSOR MAP: I'm using a single 0.9mm jet so I need to solder pads 1 & 2
AUX INPUT SELECT: default
AUX INPUT FAILSAFE: I believe this should be W?
Are these settings correct?
