Old 01-02-2012, 12:44 PM
Default Re: Aquamist 2d Install ? on an FD?
It appears the wiring can be taken from the ECU. See below:
Old 06-04-2012, 03:38 AM
Tem120 Tem120 is offline
ok its been a long time I got it all wired in , and I almost got hte car on the road
the only thing I'm lacking now is some sort of way to inject the water into the engine , just post IC ??
and also http://www.howertonengineering.net/p...Weld-Bung.html
will this work with the aqua mist 2d ?
Old 06-04-2012, 04:10 AM
hmm I have a question I dont know if this is the correct place to ask . but maybe someone can point me in the right direction ..
So when the A/I is working and functioning correctly . should it affect my Air/fuel Ratios?
will it read richer as the alcohol burns ? or will it read as if it wasn't there .
Old 04-05-2012, 04:17 PM
how do I adjust when it injects water?
its currently injecting at around 7 PSI . I'd like fori t to inject earlier
Old 11-12-2019, 11:57 PM
Rub20B Rub20B is offline
Having no experience with the kit itself I would def take either of the secondary injectors. Simply because you only need water in a boosted area, and the sec inj are on when being boosted. Using the primaries could also work but they can reach consoderable duty cycle with no or very low boost just before the secondaries get ramped in.
