Old 10-09-2013, 03:12 PM
90intherain 90intherain is offline
Default HFS-2 to HFS-3 fail safe no flow bars
I had an HFS-2 and it worked fine. I recently went to 1000cc injectors and an HFS-3. I need to know if I need to adjust threshold and gain. Also I'm not getting any flow bars. And my fail safe is kicking in. Need help. Thanks.
Old 11-09-2013, 01:07 AM
Default Re: HFS-2 to HFS-3 fail safe no flow bars
I am getting the appropriate green F-IDC.
Old 11-09-2013, 08:15 AM
If you are using 1000cc injectors, the injector duty cycle will be low. Can you put the jumper link to FDC and tell me how many bars you are reading.
Old 12-09-2013, 12:33 AM
I was only reading one. I jumpered the fav and sys to purge the system. Jumpered the bar and it was only showing 4 bars. Adjusted the bars. Went for a test drive and it all works now. Thank you!!
