Old 04-04-2016, 02:11 AM
42ryan24 42ryan24 is offline
Default how to adjust SC?
I have missed the step of setting up SC with the nozzle not installed into the cold side pipe out of the intercooler. Am I able to just adjust it by running WOT to redline and once I see 5-6 bars at some point in the pull then I will know its adjusted correctly? I would rather not take everything apart to do this adjustment if possible.
I am only getting 1 bar on the gauge during a pull. With the SC pointed at 12 o'clock it gave 1 bar, I turned it counter clock wise a bit and it did the same thing. Am I supposed to turn it clock wise?
I am running a single 1.2 mm jet with the 0.7 mm restrictor installed.
Old 06-04-2016, 08:43 AM
Default Re: how to adjust SC?
You set the SC with the SYS linked.
