Old 17-11-2012, 08:05 PM
TJ TJ is offline
Default Re: HFS-3 with big fuel injecters
Can you measure the voltage on test pin 16 relative to the "ground" pin.
1. pre-crank
2. during cranking
3. engine started and idling
4. light cruise
5. mild acceleration
6. WOT.
I shall try it in the morning
Old 17-11-2012, 08:39 PM
Once these IDC signal is noted, we can track down the late trigger problem.
Old 20-11-2012, 04:21 PM
TJ TJ is offline
I had to leave town before completing the test. I'll be away until Christmas...will conduct the test upon return.
Old 15-01-2013, 11:02 AM
TJ TJ is offline
Thumbs down Re: HFS-3 with big fuel injecters
1. pre-crank : .03
2. during cranking : 0.13
3. engine started and idling : 0.10
4. light cruise: .25
5. mild acceleration: .35
6. WOT : 2.5
Finally manager to take the measurments and the results are as above in volt.
Old 19-01-2013, 01:29 AM
It appears you are only see 50% of the fuel flow. I suggest you put in a x1.5 multiplier (underside of the circuit board). Cur x1 and link x1.5.
After solder modification please make another measure as before for me.
You should be a much healthier signal on pin 16.
