Old 26-11-2013, 03:06 PM
34plus2 34plus2 is offline
Default compound supercharged engine: where to mount nozzles?
hi,
anyone have experience on compound supercharged engines?
thanks
steven
Old 04-12-2013, 09:15 AM
Default Re: compound supercharged engine: where to mount nozzles?
Can you post some pictures?
Old 05-12-2013, 06:42 PM
Hi Richard,
yes, please have a look:
http://34plus2.jimdo.com/
a precision 6266 is feeding a roots blower.
it was supercharged before with one intercooler.
now compound supercharged, two intercoolers.
turbo - intercooler - bov - throttle body - blower -intercooler - 2 x plenums (opposed aircooled engine).
1)i was thinking about one nozzle after the first intercooler before the throttle body to cool the blower rotors 50/50 mix meth / water.
2) or just spraying 100% meth 2 nozzles before each plenum. about 10 inch away from the intake valves.
no meth controller.
i may get some kind of heat soaking from the aircooled engine even with the interoolers.
i would like to run higher boost levels up to about 2 bar oder 30 psi.
compound boost usually kicks in instantly when you start hitting the throttle.
each unit runs about 50 to 50. if tjhe turbo has 1 bar, supercharger will multiply it to 2 bar for example.
european pump gas 102 octane will be used.
thanks
steven
berlin germany
Old 05-12-2013, 07:11 PM
Amazing, the most beloved flat 4.
What target horse power are you looking for?
Old 05-12-2013, 07:32 PM
as much as i can. of course
just kidding.
fighting against higher iat`s and detonation that`s most important for me.
a 500 hp goal @ 1.5 bar would be a nice goal in my opinion.
Old 05-12-2013, 07:42 PM
more questions, what do you use to control fuel and ignition?
Old 05-12-2013, 08:33 PM
i have a stand alone ecu (megasquirt ms2/v3). i probabely switch to a kms md35.
i currently use speed density and wasted spark with a msd coil pack. iat sensor is located after the second intercooler/chargecooler. no maf.
water injection can be also controlled by the ecu, but i would like to keep it as simple as possible for now.
Old 05-12-2013, 09:15 PM
It is an interesting project, thanks for sharing. I am not much help sorry on the subject.
