HFS-5 Pump Question?
Not really sure were to post this, so im putting it here, would be nice to see a child forum open for the older systems.
What affects would putting a 135psi pump or higher 150psi on an hfs-5 have? the unit originally came with a 125psi. thanks! Last edited by infinkc; 14-07-2011 at 11:02 PM. |
Re: HFS-5 Pump Question?
Realistically the HSV is not meant for more than 125psi pressure. If needing to use one of the newer Aquatec pumps the pressure can be reduced ont he nose of the pump with the bypass adjusting screw.
