Old 31-07-2018, 09:18 PM
Fahadalamiri Fahadalamiri is offline
Exclamation Code p2563 for MK7 R
Hi Richard,
This Fahad from Dubai. I'm using aquamist hfs-4 for my Golf R Mk7. I had this fault code P2563 since one month. I tried to clear the code by deleting it, removed the battery and finally disabled the fail safe from the jumper but still the code pops up once i turn on the ignition. The aquamist and the car are working fine. I had a small problem that my car goes to limp mode once the it starts spraying the Water Methanol but its not doing that anymore, and recently i found out from the logs that i had a small boost leak and i fixed that. Any idea what would be the problem for this code P2563? I read a lot about it and shows that the actuator is not working properly so please could you confirm it before i start taking out the turbo and i have the latest version of the VCDS.
Old 01-08-2018, 07:19 AM
Default Re: Code p2563 for MK7 R
Is this a recent event or since the install of aquamist?
Old 01-08-2018, 08:06 AM
Yes actually its a recent event, It wasn't there. Does the failsafe interrupt the actuator signal?
Old 01-08-2018, 06:55 PM
I got something new today.. instead of implausible signal, i got high voltage signal and the was p2565. Do you think it's something with wiring or the actuator sensor?
Old 01-08-2018, 07:13 PM
if you disable the failsafe by linking DFS, you can then isolate aquamist from the rest of the system.If it is still showing fault, it is not aquamist, look else where.
I cannot work with too many things happening all at once.
Old 01-08-2018, 08:50 PM
Ok bro I'll try to do that.. Thanks for your time.
Old 03-08-2018, 09:02 AM
what is the engine code of this car?
Old 04-08-2018, 06:54 AM
It's ROW CJXB.. It seems like the wastegate need to be recalibrated. I'm taking the car tomorrow. I'll update you.
Note:- i disabled the failsafe but the code is still there.
Old 04-08-2018, 07:00 AM
In that case, it has nothing to do with the HFS4v3.1 system. Please do update
Tags
aquamist, fault code, mk7, p2563
