Old 01-10-2016, 07:11 PM
Joey911 Joey911 is offline
Default Re: BMW Early N55 HFS4 v3.1 installation (unfinished)
Here is diagram for the HFS4-v3.1. Please check beofere moving on.
Um whats next?
Old 12-10-2016, 07:30 PM
bump, where are you when i need you rich lol
Old 17-10-2016, 05:17 AM
Do the purging and priming as instructed in the user manual.
Old 17-10-2016, 05:26 AM
That's done. Anything else on the board? Like the MAP sensor?
Old 22-10-2016, 07:40 AM
Good. Map sensor can be tested by moving the TRIG jumper to MPS later on.
Give me an update what you have done so far, such as system prime, purge and TST tests on page 11.
Old 25-10-2016, 10:36 PM
On top of my head, got it all setup (wiring, purging, IDC jumper, gauage scale to 100% which is one bar away from full bar)
Running two 1mm nozzles, both atomized well. Was wondering if theres a restricter inside already or do I need restricter? Boost are target to max 21 psi mid range so far because of the 2.5 bar sensor, redline will drop to 15 psi or less.
Old 29-10-2016, 06:53 AM
Enjoy exploring the system for best performance. HFS4 has lots of options.
Restrictor is unnecessary.
Old 01-11-2016, 08:25 PM
I want to test the MAP sensor now, what should I do?
Old 14-12-2016, 11:06 AM
harkes harkes is offline
Hi Joey
I have recently jumped the bootmod3 ship and never got my JB4 to run properly so thinking of going the same way as you.
Did you finish your installation? How does it work - please share
- Niels
Old 14-12-2016, 03:56 PM
Move the IDC jumper to MPS, let me know it it triggers the system.
