Old 28-07-2015, 03:40 PM
blk01s4 blk01s4 is offline
Default "W.Injection" Staying partially lit
Richard, could you take a look at this ? I saw your post below about adjusting FSDL that didn't help in my case. This has been an issue since I got the unit (about a month ago). Temperature doesn't seem to be a factor here. Does it hot or cold. This doesn't impair the unit, everything works like normal. My concern is when the unit is out of warranty and something goes wrong.
Referencing post
http://www.aquamist.co.uk/vbulletin/...ead.php?t=2730
Old 28-07-2015, 06:24 PM
Default Re: "W.Injection" Staying partially lit
Not sure what caused this, Can you disable the failsafe (DFS) ans see if it cures it. Also put duct tape on the back on gauge. Condensation may cause this.
Old 28-07-2015, 06:58 PM
Hi Richard, I don't think its a condensation problem as this has been going on since I got the kit. Out of the box I plugged everything in to see if it was functioning before installing and it was doing that. I'll disable the fail-safe. Could you provide any detail as to why you want me to disable the fail-safe as a test? I did try a brand new gauge cable thinking perhaps a crimp was bad. Same problem.
Old 28-07-2015, 08:20 PM
The top yellow led is solely responsible for failsafe. I doubt failsafe is the cause.
Most likely to be a dry joint. Can you take a Hi-res picture and send it to Richard at aquamist.co.uk I like to examine a few surface mount components.
If I see a suspect joint, can you solder? Just needs re-flowing.
Old 28-07-2015, 08:28 PM
Im assuming you want me to take a high res photo of the back of the dash gauge's circuit board? I can probably re-solder, however will this void the warranty?
Old 28-07-2015, 08:34 PM
Yes, the back of the gauge circuit board. The bezel unscrews.
I will take care of the warranty for you. Provided oyu do drop a big blob of solder onto the circuit board.
Old 28-07-2015, 08:52 PM
No worries sir im pretty good with the ole soldering iron! I'll get the pictures tonight
Old 30-07-2015, 07:45 PM
Still have not received the picture.
Old 31-07-2015, 02:30 PM
Hi Richard, haven't had a chance yet to take the vent out of my car. I'll be gone this weekend. should have the picture Monday.
Old 06-08-2015, 04:19 AM
Hi Richard YGM!
